Acceder a la Bateria del XKR
Publicado: 19 Ene 2014 03:11
por axortruck
Hola foreros:
Me podeis decir por donde y como se accede a la batería del XKR del 2007, si es preciso cambiarla. Hoy, después de estar el coche parado seis o siete semanas no me ha arrancado y he tenido que cargarlo con el cargador que tengo casero. Me temo que no tardando mucho tenga que sustituirla.
Subido el coche en el elevador y mirando desde abajo no se ve nada. Me imagino que la bateria este debajo del asiento trasero. ¿ Me podeis ayudar ?
Gracias anticipadas
Re: Acceder a la Bateria del XKR
Publicado: 19 Ene 2014 08:44
detrás de los asientos, según el manual ...
BATTERY ACCESS
To gain access to the battery, remove the
access cover as follows:
1. Unscrew and remove the four luggage
retention hooks from the cover.
2. Pull the cover rearwards and remove from
the vehicle.
Store the hooks and cover in a safe place and
remember to refit them when access to the
battery is no longer needed.
y procedimento para poner pinzas:
The following procedure must be followed
exactly:
1. Remove the left-hand side luggage
compartment trim panel cover, to access
the vehicle battery positive (+) remote
charge terminal, remove the protective cap
from the terminal.
2. Attach one end of the red booster cable to
the positive (+) terminal of the booster
battery and the other end to the positive (+)
remote charge terminal of the vehicle.
3. Lift the luggage compartment floor panel
to reveal the spare wheel. Remove the
protective cap from the negative (-) remote
4. Attach one end of the black booster cable
to the negative (-) terminal of the donor
battery and the other end to the negative
(-) remote charge terminal of the vehicle.
5. Start the disabled vehicle. Allow the engine
to idle for five minutes before
disconnecting the cables.
Disconnecting the cables
1. Disconnect the black booster cable from
the negative (-) remote charge terminal of
the vehicle and the donor battery negative
(-) terminal.
2. Disconnect the red booster cable from the
positive (+) remote charge terminal of the
vehicle and the donor battery positive (+)
terminal.
3. Refit the terminal covers, trim panel and
luggage compartment floor panel.
It may be necessary to reset the electric
parking brake. See ELECTRIC PARKING
BRAKE (EPB) (page 142).
E91691
Publicado: 19 Ene 2014 21:43
por Kamicacekkk
TheShadow escribió:detrás de los asientos, según el manual ...
BATTERY ACCESS
the vehicle.
exactly:
from the terminal.
(-) terminal.
terminal.
E91691
Y te as quedao tan a gusto.
jesus
Publicado: 20 Ene 2014 08:05
muyyyyy agustitoooo
Publicado: 22 Ene 2014 14:02
por frc
Hola.
La mía, está situada en el maletero, a la derecha, protegida por una tapa, imagino que la del tuyo debe andar por ahí???
