Buenas noches compañeros.
¿Alguien sabe desmontar la cartonera de la puerta trasera?
Es que me ha dejado de sonar un altavoz, y mucho me temo que se haya \"soltado\" algún cable.
Lo digo para cuando tenga un hueco y me ponga de \"ñapas\" en el patio.
Desmontar cartonera puerta trasera.
- Jesús Joaquín
- Jesús Joaquín
- Jorge XJ40
Chico, es fácil que nadie del foro lo haya hecho...
Cuando necesito ayuda \"técnica\" entro en jag-lovers.com y allí hay miles de post con consultas/respuestas, un ratillo con el buscador y sale todo.
No es necesario preguntar ni he participado directamente (0 posts desde que me registré), pero busco \"search\" y a mirar... en inglés, claro.
A ver si encuentro algo qu te ayude
- Jorge XJ40
Try:
Remove the front door interior handle bezel (plastic surround) by carefully
prising it off (don't damage the panel!). Remove the front door trim panel
retaining screw cover (plastic clip cover in the bottom of the door pull
well under the rubber insert). Remove the front door trim panel retaining
screws. Detach the front door trim panel - to aid removal release the top
clip at the door lock end of the panel by lowering the glass and pressing
the panel inward. Disconnect the front door trim panel harness electrical
connector. Remove the front door trim panel. Disconnect the driver door
module electrical connector. To install, reverse the removal procedure.
Hope this is clear enough.
Regards
Regards
- Jorge XJ40
Jo me lié LO DE ANTES ES PARA EL S TYPE!!
PARA EL X TYPE:
Hi,
Has anyone done this? I'm following the instructions below from the
JTIS CD. I've got as far as step 3 detaching the clips but I can't
remove the panel as the door handle appears to be holding it in
place. I can't see the cable let alone detach it as instructed in
step 4 because the panel is still there. Help!!
1)Remove the retaining screw cover.
2)Remove the retaining screws.
3)Detach the front door trim panel.
4)Detach the door handle cable.
5)Remove the door handle cable.
6)Remove the front door trim panel.
7)Disconnect the electrical connectors and detach the wiring
harness.
03 X Type 2.5 Sport, ex '95 XJR, ex '85 4.2 Sov
Lancashire, United Kingdom
--Posted using JagFORUM--
Re: [x-type] Door Trim Panel Removal
From JOHN FEW [johnnyfew at hotmail dot com]
16 Posts since 2nd Jun 2003
Received: Wed, 10 Jan 2007 16:14:23 CET
Reply to Forum | Reply Privately | New Forum Topic
In reply to a message from Glenn B sent Sun 7 Jan 2007:
Hi Glenn
thanks for your reply regarding my water ingrees problem.Yes the
drain holes are clear and the membrane is intact.The problem I have
is very clear I have water droplets coming from the latch assembly
which is at the end of the door half way up and this runs down to
where the door tread above the seal is and settles here with no
escape because is in the middle between the two rubber seals.Once
it has built up sufficient volume it rises above the seal attached
to the car and floods over into the footwells.Back to your door
panel removal problem everything you have done is correct it will
feel tight when you pull the panel away from door the cable is
hooked on the door by a clip and this tends to hold the panel
back.If you pull the panel towards you and look over the top you
will see this clip and cable holding things back and you should be
able to release it from clip and proceed to remove panel.
John
JOHN FEW
PARA EL X TYPE:
Hi,
harness.
Hi Glenn
John
JOHN FEW
- Jesús Joaquín
Pues a ver si saco un rato y lo intento, pero me da miedo a romper algo
Muchas gracias por la información Jorge.
Por cierto, me anoto esa página.
Ah!, lo último, a ver que sabes de este modelo: http://www.forojaguar.com/foro/viewtopic.php?t=795
